Thread: What did you do to your car today? Vol 2.0
Page 457 of 474 FirstFirst ... 357407447455456457458459467 ... LastLast
Results 9,121 to 9,140 of 9466
  1. #9121 Re: What did you do to your car today? Vol 2.0
    Jan 2014
    AR
    I can think of a several whys
    Yesterday I swapped the cruise unit and cable on the GT, off the 02. Works like a champ. The flat rope in the control box tore in half. I figure it is possibly wreck related just took awhile to stop working.
  2. #9122 Re: What did you do to your car today? Vol 2.0
    Wichita
    Got a job about 2 miles from the house a few months back. Driving to and from work is about all I do rn. Probably all any of us who still work do. I have discovered my MPG's plummeted to 15.8. Not great and not horrible.
  3. #9123 Re: What did you do to your car today? Vol 2.0
    i got one of them jobs, less then 5 miles round trip. where the mpg on the dic drop to the basement, your only filling up once a month now. at least thats how i roll.
    even since selling the regal and dd the tahoe. its got a bigger tank and a v8, but it still lasts a month.
  4. #9124 Re: What did you do to your car today? Vol 2.0
    I've driven my truck 8,500 miles, the avg mpg is 12.5 over that with 95% city.
  5. #9125 Re: What did you do to your car today? Vol 2.0
    Wichita
    Anyone know how to tell whether it's the power steering pump or the steering rack that I need?
  6. #9126 Re: What did you do to your car today? Vol 2.0
    whats it doing? hard to turn left? thats the rack.
  7. #9127 Re: What did you do to your car today? Vol 2.0
    Wichita
    Not hard to turn left. It makes that grinding noise when turning while moving.
  8. #9128 Re: What did you do to your car today? Vol 2.0
    you also hear the pump whining? and the wheel is not smooth to turn. could be the pump.
  9. #9129 Re: What did you do to your car today? Vol 2.0
    Wichita
    I'll have to listen for it.
  10. #9130 Re: What did you do to your car today? Vol 2.0
    St. Louis
    I finally gave the GP a much needed wash today. Been over 2 months and it was looking horrible. Lot going on in life lately and the cars have kinda suffered. Might throw it in the garage tomorrow and give it a quick buff and wax that it needs. Clear is really starting to haze on the decklid and SLP spoiler again
    I should take a few days off of work and break out my new Flex XC that I bought and learn how to use it. I'd bet it can pull out the shine if I do it right, just never used a really nice polishing machine before so I need to practice. I should clay it to start with too most likely.
  11. #9131 Re: What did you do to your car today? Vol 2.0
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Same. Did a quick 30min wash to the GXP to cruise the local parade with the Fire Dept and various classics. Living under trees now and it shows, so I should get a little more frequent with washing all 3 vehicles.
  12. #9132 Re: What did you do to your car today? Vol 2.0
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Picked up a new to me 2000 with 155k on the clock with a rebuilt engine. Forgot alot about these old crates but I'm quickly remembering. So far I've, fixed the water in flood boards, fixed a brake line, 180* tstat, cleaned the throttle body, washed it multiple times, (now needs buffed) replaced a burned out fog bulb, and put in some autolite 605's. Still need to change the supercharger oil, and port the supercharger. Might do that all in one fail swoop.
    Future plans are, tint all the way around, headers, replace the catback system as it is rusting out. Thinking a glass pack res to a chambered muffler of some sort. Probably will ditch the dual muffler at that point because I'm lazy and a y pipe to another muffler is pointless weight. Then to get a tune for those mods and see if the old girl is ready for a pulley drop.
    Overall a decently clean car. Will need new tires as it sat for over a year and the tires on it are slightly weather cracked. Pretty sure it needs a hub assembly too because the tcs off light is always on and has a slight shimmy turning right. Someone ran boost in overdrive and now it has the od Mia mod so that will need rectified, but the guy I bought if off of said he'd pay for a junkyard tranny and my cousin owns a repair shop so simple enough of a fix. Broke the throttle body gasket so now gotta fix that. Glad I knew going into this it was going to be a project car. [emoji23]
    Sent from my SM-G973U using Tapatalk
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  13. #9133 Re: What did you do to your car today? Vol 2.0
    May 2020
    Pittsburgh
    Hm. Today's hopper is to install shortened axles to remedy axle bind. We'll see how it goes...
    And maybe try to figure out why my cruise control doesn't work since I tuned it.
  14. #9134 Re: What did you do to your car today? Vol 2.0
    Jan 2014
    AR
    GTP got hauled off to a transmission shop yesterday. Trump is paying half. Broke it on February 13 on black ice.
  15. Dislikes Scottydoggs disliked this post
  16. #9135 Re: What did you do to your car today? Vol 2.0
    Oct 2014
    portland oregon
    Quote Originally Posted by idrivejunk View Post
    [emoji44]
    Sent from my SM-N920V using Tapatalk
  17. #9136 Re: What did you do to your car today? Vol 2.0
    St. Louis
    Ordered new plugs/wires. Time for another ~90K mile tune up. Existing plugs look ok just getting worn. Also finally ordered a replacement drivers side axle so I can remedy the clunk and hopefully the vibration that I've been dealing with for over a year. Still thinking I need some spacers to account for the lowering but will see what the new axle does first.
  18. #9137 Re: What did you do to your car today? Vol 2.0
    Jan 2014
    AR
    Quote Originally Posted by wowitsfast View Post
    [emoji44]
    I don't know what emoji 44 looks like or how come I got a dislike for what I said.
    I am aware theres not many things I could do that are stupider but crushing a better body than the GT didn't make sense to me.
  19. #9138 Re: What did you do to your car today? Vol 2.0
    disliked the tranny taking a crap. cant hardly "like" that news. could i?
  20. #9139 Re: What did you do to your car today? Vol 2.0
    Jan 2014
    AR
    No worry. Like that its getting fixed. I got the price is right loser horn from ya on it already on post 9110.
  21. #9140 Re: What did you do to your car today? Vol 2.0
    Nov 2012
    Madison
    Quote Originally Posted by FordMan77 View Post
    3401?
    You did it right the first time. Yeah clay first, you dont want to grind stuff into the paint.
    I have had mine for over 6 years and love it. Make sure you get the Lake Country Force pads.
    I have the smaller 4 3/8 backing plate since I use the 5.5" Force pads.
  1. Just got a GTP today !!!
    By Dobbs122 in forum Off Topic Discussion
    Last Post: 06-06-2011, 12:05 PM
  2. Buy yours TODAY!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 05-29-2011, 03:17 AM
  3. SO Today I did.......
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 11-09-2008, 11:26 PM
  4. look what come today?
    By nemesis in forum Tires & Wheels
    Last Post: 07-16-2008, 01:01 PM
