Thread: 2008 GP Base with 3.8 engine oil maximum capacity ??
Results 1 to 11 of 11
  1. #1 2008 GP Base with 3.8 engine oil maximum capacity ??
    Nov 2019
    Wi
    What is the maximum oil capacity of 3.8 engine?
  2. #2 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    GTP Level Member
    Oct 2014
    4.5 quarts. It will take 5 because they usually leak.
  3. #3 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    Nov 2019
    Wi
    Actually I want to know the MAXIMUM capacity ... NOT the NORMAL capacity !
    My grandson has this 2008 GP with 3.8 ... looks like some filled oil twice ...about 3/4 inch above full mark !
    We drained some .. still over full !
  4. #4 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    GT Level Member Supercharged99's Avatar
    Apr 2011
    Kansas City, Mo
    Quote Originally Posted by GP2005GXP View Post
    I'm confused on why the answer matters. If it's over full, then just drain til it's not over full anymore. Not sure anyone knows the answer to how much can the engine actually take up to the brim. Obviously, that's not good to the long term health of the engine anyway.
    1999 GTP...stock for now
    2007 Suburban...far from stock
    1991 GMC Dually...74k original miles. Work in progress. Far from done.
    1977 C-10 (my baby)...too many mods to list
  5. Likes tomsteve liked this post
  6. #5 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    id suck it out the dip stick with clear tubing, you need enough tubing to be deep in the oil pan then over the bumper to the ground, then siphon it out to a empty oil qt bottle. once its full. pull the tube and check the level. repeat if need be.
    being its winter, warm the engine up first so the oils hot and thinner, will come out way easier vs cold.
  7. #6 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    GTP Level Member
    Oct 2014
    Or use a vacuum extractor through the dipstick. Insert the tube to the full level on the dipstick and suck until it quits.
  8. #7 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    Nov 2019
    Wi
    [QUOTE=GP2005GXP;1500785]Actually I want to know the MAXIMUM capacity ... NOT the NORMAL capacity !
    My grandson has this 2008 GP with 3.8 ... looks like someone filled oil twice ...about 3/4 inch above full mark !
    It is all oil ... NO coolant !
    We drained some .. still over full ![
  9. #8 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    Cool story man.
    As said, if it's over the full mark keep draining the oil out until it's not over full.
    To answer part of your question, you could probably dump in 20 quarts of oil before it would start pouring out the valve covers. But by this time if you attempted to start the engine it would likely reverse hydrolock because the crank/pistons can't spin because it's completely full of oil.
    At roughly 6-7 quarts of oil the crank would be slapping the oil causing it to foam and may lead to damage.
  10. Likes Supercharged99, tomsteve liked this post
  11. #9 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    Apr 2015
    Columbus, OH
    So....huh? If you speculate that someone filled the oil twice without draining it, why don't you just remove about 4.5 qts and check? You said you drained"some". Drain more till it reads full on the dipstick.
    Top Swapped 01 Imp
  12. #10 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    GT Level Member mguzzo's Avatar
    Buffalo NY
    or better yet, completely drain it then put 4.5 qts in so you know exactly how much is in there.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  13. Likes bandook, tomsteve, Supercharged99 liked this post
  14. #11 Re: 2008 GP Base with 3.8 engine oil maximum capacity ??
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by mguzzo View Post
    thats just too logical
    08 grand prix NA3800
  15. Likes Supercharged99 liked this post
  1. 2008 grand prix base rim MN
    By markpa in forum General Grand Prix Discussion
    Last Post: 04-15-2018, 07:08 PM
  2. Oil capacity for GP 2008 3.8L
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 06-20-2017, 08:53 PM
  3. 2008 Base Dual Exhaust?
    By Viper79 in forum Visual/Body Modifications
    Last Post: 12-31-2014, 11:51 AM
  4. Went from 2007 Base to 2008 GXP
    By jeangreyfan in forum Members Rides
    Last Post: 05-12-2012, 11:45 PM
  5. Cold Air Intake 2008 (Base 3.8)
    By lolwtf in forum General Tech Discussion
    Last Post: 04-10-2011, 04:10 PM
