Thread: 04 gtp swaybar?
Results 1 to 14 of 14
  1. #1 04 gtp swaybar?
    Sep 2011
    Omaha
    My 04 gtp has a crack or two in the swaybar...does anyone know the stock options for a replacement. Its for the front end. Also its not the comp g. I'm not sure what the size is..
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: 04 gtp swaybar?
    Aug 2011
    'Merica
    Rock Auto will help you out, or measure it with a set of Calipers.
  3. #3 Re: 04 gtp swaybar?
    Sep 2011
    Omaha
    Rock auto only has the rear swaybar
  4. #4 Re: 04 gtp swaybar?
    Aug 2011
    'Merica
    Advanced only has the rear too. Interesting.
  5. #5 Re: 04 gtp swaybar?
    Arizona
    Grab a 20mm
  6. #6 Re: 04 gtp swaybar?
    Sep 2011
    Omaha
    From where? I cant find any thing other than oem off gmpartsnow.com
  7. #7 Re: 04 gtp swaybar?
    Arizona
    There not specific just google 20mm energy suspension bushings etc... They'll come up
  8. #8 Re: 04 gtp swaybar?
    Pics of said cracks in sway bar? They are normally pretty solid.
  9. #9 Re: 04 gtp swaybar?
    Oct 2011
    Toledo, OH
    Factory one is hollow. It weighs like 3lbs.
    7"
  10. #10 Re: 04 gtp swaybar?
    On the 04-05?
  11. #11 Re: 04 gtp swaybar?
    Oct 2011
    Toledo, OH
    On the 04-05?
    Yep. IIRC base and GTP front is hollow, Comp-G is same size but solid. I know for a fact my factory rear was hollow but the GMPP one is the same size and weighed a good deal more, presumably solid.
    7"
  12. #12 Re: 04 gtp swaybar?
    Oct 2011
    Toledo, OH
    Suspension
    Grand Prix is known for handling smooth stretches of interstate or curvy country roads equally well. WideTrack is key to its flat cornering and superb handling characteristics, even when the road is uneven. With the wheels wider apart, less weight is transferred in the turns and tire loads are more evenly balanced. At the heart of WideTrack handling is a four-wheel independent suspension featuring MacPherson struts wîth coil springs, lower A-arm and a 20-mm solid anti-roll bar in the front. Grand Prix's rear independent suspension features a tri-link coil-over-strut design and a 17.2-mm anti-roll bar on the GT and GTP. A 20-mm hollow anti-roll bar is used on the Comp G package. The result is a sportier ride wîth a solid, balanced feel that can make even a run to the grocery store a satisfying experience.
    So I see the fronts ARE solid, and I apparently had a Comp-G rear installed previously, because angle grinders do not lie.
    7"
  13. #13 Re: 04 gtp swaybar?
    Sep 2011
    Omaha
    Quote Originally Posted by 91parkave View Post
    For the entire front swaybar???
    I just put moog endings on before lit cracked.
  14. #14 Re: 04 gtp swaybar?
    Sep 2011
    Omaha
    Quote Originally Posted by industrialfish View Post
    Suspension
    I thought solid was better handling than hollow?? Or is it basically the same just less weight for hollow via unsprung weight??
    What's the difference between the ride and handling vs. The sport suspension? Sport suspension=comp g?
  1. Swaybar Sizes
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2024, 05:51 AM
  2. Comp G Swaybar bushing
    By Lishap in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2014, 01:13 PM
  3. The all to common DP hitting the Swaybar
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 03-02-2013, 02:17 AM
  4. swaybar install
    By GTP GTP GTP in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2012, 05:34 PM
  5. Swaybar Brackets...
    Last Post: 11-13-2009, 01:07 PM
