Thread: Reduced engine power 2 codes
Results 1 to 20 of 25
  1. #1 Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    On my way to work today all of the sudden on my 2004 Pontiac grand prix I get reduced engine check tcs the car will idle but I press the gas nothing just revs a little and bogs down at like 1500 rpm's threw codes p1518 - throttle actuator control module and p0102- mass air flow or map so not sure I have recently cleaned the tb and mass air sensor checked and cleaned ground wires not sure where do go from here any help is greatly appreciated
    Sent from my MB865 using Tapatalk
  2. #2 Re: Reduced engine power 2 codes
    Dec 2012
    troll land
    Either the motor in the tb or the gas peddle is bad
  3. #3 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Maybe I'll get lucky and it will be the peddle its cheaper than the tb
  4. #4 Re: Reduced engine power 2 codes
    Make sure you don't have a vacuum leak at the tb.
  5. #5 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    I wish I did I checked all my vacuum lines but thanks to both of you
  6. #6 Re: Reduced engine power 2 codes
    Try unplugging the maf and start it.
  7. #7 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Did that too doesn't act any different
  8. #8 Re: Reduced engine power 2 codes
    Have you tried just clearing the codes and see if they come back?
  9. #9 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Clearing them by unplugging the battery?
  10. #10 Re: Reduced engine power 2 codes
    or with a scan tool
  11. #11 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Don't have a scan but I tried disconnecting the battery for a few minutes and that didn't work so its been sitting for like an hour. Or so now gonna go back out and see what happens
  12. #12 Re: Reduced engine power 2 codes
    it usually takes a good 30 minutes to clear a code by unhooking the battery.
  13. #13 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Thanks that's good to know
  14. #14 Re: Reduced engine power 2 codes
    it helps to touch the disconnected cables together to get rid of residual power.
  15. #15 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    So I've reset the system had the battery unplugged over an hour to clear the codes of it did clear them they came right back so I'm hoping the pedal sensor is the problem but won't know for awhile just gonna go back to driving my 02 bonnie ssei for now
  16. #16 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Thanks for everybody's input and help it is greatly appreciated
  17. #17 Re: Reduced engine power 2 codes
    Could very well be the pedal assembly then
  18. #18 Re: Reduced engine power 2 codes
    Donating Users
    Oct 2012
    lake city,fl
    Well put in a new/used but good pedal sensor and same issue so does that mean I need a new throttle body?
  19. #19 Re: Reduced engine power 2 codes
    http://engine-codes.com/p1518_buick.html
    Possible causes
    - Dead or weak battery
    - Faulty Throttle Actuator Control (TAC) module
    - Throttle Actuator Control (TAC) module harness is ope or shorted
    - Throttle Actuator Control (TAC) module circuit poor electrical connection
    - Check Throttle Actuator Control (TAC) module connector for water
    this part is on the TB check the wires to it, they bake in the exhaust heat.
    Read more: http://engine-codes.com/p1518_buick.html#ixzz2tQjtqDND
  20. #20 Re: Reduced engine power 2 codes
    Did you unhook the battery to reset everything?
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 04 GTP Reduced Engine Power
    By orange57 in forum General Tech Discussion
    Last Post: 07-30-2013, 12:56 AM
  3. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  4. Reduced engine power. Help!
    By Jeremy1279 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 06:54 PM
  5. Reduced Engine Power???
    By 05gtPEACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2010, 06:21 PM
