Thread: Flat tire sound, but no flat tire?
Results 1 to 4 of 4
  1. #1 Flat tire sound, but no flat tire?
    SE Level Member biggd1980's Avatar
    Feb 2013
    Iowa
    I just recently changed the front wheel bearings on my 04 Grand Prix GT2. Since then I have been getting a flat tire sound from the front driver side when driving at lower speeds. It is the most noticeable when driving on asphalt (black top style roads). The alignment did get knocked off very slightly after the beating it took to get the passenger side bearing off, and will be taking that in for adjustment. Could the alignment be the issue? If not, any other ideas? The noise wasn't there before changing the bearings.
  2. #2 Re: Flat tire sound, but no flat tire?
    Did you torque the cv nut down?
  3. #3 Re: Flat tire sound, but no flat tire?
    Jan 2009
    Tallahassee, FL
    Look at the axle nut
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: Flat tire sound, but no flat tire?
    I live here. DirtDog's Avatar
    Jun 2012
    Make sure the nut on the end of the CV shaft is tightened down
  1. flat paint
    By dlk in forum Visual/Body Modifications
    Last Post: 08-23-2013, 11:55 AM
  2. Intermittent flat tire feeling..
    By genocide in forum Brakes/Suspension/Chassis
    Last Post: 03-23-2011, 11:48 AM
  3. car falling flat
    By redrebel82 in forum General Tech Discussion
    Last Post: 02-08-2011, 11:14 PM
  4. Flat black GTP?
    By Death in forum Visual/Body Modifications
    Last Post: 09-11-2010, 04:16 PM
  5. fix a flat aerosol can
    By nemesis in forum Tires & Wheels
    Last Post: 08-18-2008, 02:13 PM
