Thread: 2004 GTP crank sensor
Results 1 to 2 of 2
  1. #1 2004 GTP crank sensor
    May 2012
    goldsboro nc
    Just a quick question
    Im looking at a 2004 gtp that will not crank the current owner told me that it needs a new crank position sensor
    He has replaced just about every other piece of the electrical system but has not replaced the sensor when it seems that this would fix the problem and make the car run again
    Would this sensor prevent it from firing up
    it turns over but just will not fore up
    I want to know if i should proceed in getting the car
  2. #2 Re: 2004 GTP crank sensor
    Well does it have spark at the coil packs or voltage to the ICM??
    Here is a little step by step for testing the crank sensor.
    Part 1 -How to Test the 3.8L GM Crank Sensor With a Multimeter
  1. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  2. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
