Thread: Magnaflow cat back exhaust kit
Results 1 to 9 of 9
  1. #1 Magnaflow cat back exhaust kit
    SE Level Member rhenuset's Avatar
    winnipeg
    Does anyone know if the Magnaflow cat back exhaust kit (16726) works on all models? It says its for the GXP but I'm a GT owner so I'm a little curious. I cut out my res and put in a magnaflow glasspack, it was loud at first but now that its broken in I dont really notice it
  2. #2 Re: Magnaflow cat back exhaust kit
    winnipeg
    Also I'm sure the 97-03 exhaust systems would fit 04+? just need a confirmation thanks
  3. #3 Re: Magnaflow cat back exhaust kit
    Just buy new mufflers instead of spending triple the amount on a cat-back system.
  4. #4 Re: Magnaflow cat back exhaust kit
    Omaha, NE
    The two concerns would be hangers and the connection at the down pipe. I'm not sure either way, but I would say it probably won't fit.
    Like cam said, mufflers for sound, and replace your resonator with a glass pack for better flow and no cackle.
  5. #5 Re: Magnaflow cat back exhaust kit
    winnipeg
    Has anyone used the gxp or 97-03 kit on an 04+ v6?
  6. #6 Re: Magnaflow cat back exhaust kit
    Wichita
    The difference is in the connection at the downpipe. Hangar spots are all the same.
  7. #7 Re: Magnaflow cat back exhaust kit
    SE Level Member Reverant GTP's Avatar
    Iowa
    If you look at the specs the GXP has larger exhaust tips and resonator iirc
  8. #8 Re: Magnaflow cat back exhaust kit
    winnipeg
    Where the dp connects I assumer it would be a bigger opening?
  9. #9 Re: Magnaflow cat back exhaust kit
    GTP Level Member joshv's Avatar
    canada
    ur car will sound terrible either way... spend less money on mufflers or no mufflers
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  1. How to polish and restore aluminum exhaust. (Magnaflow)
    By Jbruce308 in forum How To Write-Ups/Tech Tips
    Last Post: 02-17-2013, 12:36 AM
  2. Magnaflow cat back system.
    By buckslayer in forum General Tech Discussion
    Last Post: 01-26-2011, 08:58 PM
  3. I guess I'm getting old - Magnaflow Exhaust
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2009, 03:05 PM
