Thread: 05 Fuel Filter
Results 1 to 12 of 12
  1. #1 05 Fuel Filter
    Grantham NH
    Does the 05 Prix have a non-servicable Fuel filter
    with 47,000 on it I figured I should change it as It probably hadn't been done But the two parts stores I went to Have NO listing so I am coming to the conclusion that it is Either Non-servicable or it is a dealer item only (which either way Ticks me OFF)
    Or are both people just Idiots (I have run into this a lot with part stores around here)
    Sorry if this is in the wrong section
  2. #2 Re: 05 Fuel Filter
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    Quote Originally Posted by gfdeputy2 View Post
    It doesn't have a fuel filter only the sock on the fuel pump
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  3. #3 Re: 05 Fuel Filter
    Grantham NH
    Thanks
    Don't know if I like that or not
  4. #4 Re: 05 Fuel Filter
    Apr 2008
    ny
    I don't
  5. #5 Re: 05 Fuel Filter
    Grantham NH
    Yeah
    why would you do that
    looks like I may be replacing the fuel pump some time soon
  6. #6 Re: 05 Fuel Filter
    Central Texas
    Same for an '06? I've seen a pic somewhere of the 'in-tank' screen or whatever. So there's no filter to replace?
    WTH is that about, GM!!!
    -- Mike --
    2006 Grand Prix, 3.8L; all stock (..for now ..)
  7. #7 Re: 05 Fuel Filter
    GTP Level Member dstout's Avatar
    ky
    Why did they put it on the fuel pump and how long will that last?
  8. #8 Re: 05 Fuel Filter
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    it will last as long as the pump does.
  9. #9 Re: 05 Fuel Filter
    SE Level Member chili's Avatar
    MN
    That's strange, didn't realize that. My 04 has a filter, changed it long ago and was going to get at it again.
    04 CompG, DP, Wizair, 180 t-stat, 18" Verde 5ives, my DD...170,000 and counting!
  10. #10 Re: 05 Fuel Filter
    Dec 2008
    TEXAS
    they sell the filter screens on thier own , you just have to match up the old with the new , they wont find it under a specific car .
  11. #11 Re: 05 Fuel Filter
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    my 04 has a fuel filter... why doesnt 05?
  12. #12 Re: 05 Fuel Filter
    Apr 2009
    Baton Rouge, Louisiana
    Dam after hearing all this does an 07 GT have a fuel filter? I have a little over 32000 on my car. I would be inclined to change it soon if it has one.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  5. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
