Thread: Heater Core Replacement
Results 21 to 40 of 59
  1. #21 Re: Heater Core Replacement
    theres other how to's with real pics too. take a search for them.
    what the whole crappy job amounts to is removing every gold bolt you see around the bottom of the hvac box there, theres 2 layers.
    and of course, leap frogging from one side to the other removing these bolts.
    a good flash light or small drop light is a huge help, as you cant see jack for a lot of the bolts.
    a beer or two to loosen yourself up helps, as well the aspirin for your back when done.
    i dont know if it said so in this how to. but take the hoses off the alt bracket, and blow the core out, this way you dont spill any in the car when taking the core out.
    and on the firewall from the inside is a screw holding the two tubes to the wall. you can see it sticking out on the outside of the fire wall between the in and out lines. thats the last bolt you'll get out. then the core will come out.
  2. #22 Re: Heater Core Replacement
    Dec 2014
    DTW
    Jerseydoggs:
    Interestingly enough, on my 2004 Grand Prix there wasn't a screw on the firewall holding the two tubes
    in place. Once the heater core was exposed and the hoses removed, the unit slipped right out.
    All:
    What brand heater core do most people use as a replacement. I bought an OEM AC Delco Heater Core
    from Amazon and I'm a little concerned that the two crimped on tubes can rotate with not a lot of effort
    (they aren't loosey/goosey). The tubes on my original heater core are crimped rock solid into place and
    don't rotate.
    Is this normal? Just seems like obvious place for a new leak.
    I'd hate to get it all back together and have it leak again right away.
    BB
  3. #23 Re: Heater Core Replacement
    I used a dramas one. Hoses moved around easily
  4. #24 Re: Heater Core Replacement
    SWPA
    Yes the aftermarket ones are meant to rotate so that you can get them into proper orientation.
  5. #25 Re: Heater Core Replacement
    Oct 2015
    Elyria
    Do you need to remove the complete dash to do this job? I'm part way into it and working on chiseling the heat stakes now. I took a break and looked on YouTube and there's a guy that completely removed the dash.
  6. #26 Re: Heater Core Replacement
    the dash stays put, no need for all that jazz.
  7. #27 Re: Heater Core Replacement
    SWPA
    I did not remove my whole dash, but the job wasn't fun.
  8. #28 Re: Heater Core Replacement
    oh, no one said its pretty lol
  9. #29 Re: Heater Core Replacement
    SWPA
    LOL. The worst thing about that day is I was struggling with a sinus issue as well as a migraine. I crawled out from under the dash one time and thought I was going to vomit due to the caused disorientation.
  10. #30 Re: Heater Core Replacement
    Oct 2015
    Elyria
    Okay thanks. I took the seats out so it would be easier to lay under it. What a pain in the ass. I chisel the heat stakes and then have to heat them up with a lighter to get them to come apart.
  11. #31 Re: Heater Core Replacement
    that looks about right, left side get in undo stuff, right side find and remove more stuff, back to the left side over and over again lol
  12. #32 Re: Heater Core Replacement
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    What's with the lighter on the floor lol?
  13. #33 Re: Heater Core Replacement
    read the posts man.
  14. #34 Re: Heater Core Replacement
    Jan 2014
    AR
    Must be for applying heat to them stakes, ha ha. Mmm steak. There should be no chiseling required on a heater core replacement, I'm puzzled.
  15. #35 Re: Heater Core Replacement
    SWPA
    On 04+ the covers are held in place by plastic stakes that are melted. Dumbest design ever, but then again it is GM.
  16. #36 Re: Heater Core Replacement
    Jan 2014
    AR
    Ah, figured he was talking about melted pins... its all screws on 97-03.
  17. #37 Re: Heater Core Replacement
    04 up are special, got extra dumb stuff added.
  18. #38 Re: Heater Core Replacement
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Damn, I've been procrastinating on this job for months. I guess I have to do it now since winter is approaching. My neighbor asked me to help replace the core on his '02 Taurus as well. This week's gonna blow
  19. #39 Re: Heater Core Replacement
    i looked the taurus one up, and wow. thank god moms didnt need one. but the dumb ass heater core water line circle aka by pass lines rusted out, now thats no fun to change.
    what a crap idea they had. ford at its finest......
  20. #40 Re: Heater Core Replacement
    Apr 2009
    Upper Darby, PA
    Yeah they are a ***** to work on. I thought the Gp's were bad lol
  1. Heater Core Replacement 97-03
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 01-20-2022, 05:21 PM
  2. heater core
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-01-2011, 12:29 PM
  3. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. Heater core replacement....
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-19-2008, 10:10 PM
