All following information listed is for a 04 N/A, It should remain the same for all 2004+ Naturally Aspriated or Supercharged applications. If any errors or variances are found please contact me via PM to have the information corrected.
Brakes and Traction Control
System Specifications
HYDRAULIC BRAKE SYSTEM
Delco Supreme II Brake Fluid or equivalent DOT-3 brake fluid.
Cooling System Information
ENGINE COOLANT
The cooling system in your vehicle is filled with DEX-COOL engine coolant. This coolant is designed to remain in your vehicle for 5 years or 150,000 miles (240 000 km), whichever occurs first, if you add only DEX-COOL extended life coolant.
A 50/50 mixture of clean, drinkable water and DEX-COOL coolant will:
•Give freezing protection down to -34°F (-37°C).
•Give boiling protection up to 265°F (129°C).
•Protect against rust and corrosion.
•Help keep the proper engine temperature.
•Let the warning lights and gages work as they should.
NOTICE: Using coolant other than DEX-COOL may cause premature engine, heater core or radiator corrosion. In addition, the engine coolant may require changing sooner, at 30,000 miles (50 000 km) or 24 months, whichever occurs first. Any repairs would not be covered by your warranty. Always use DEX-COOL (silicate-free) coolant in your vehicle.
WHAT TO USE
Use a mixture of one-half clean, drinkable water and one-half DEX-COOL coolant which won't damage aluminum parts. If you use this coolant mixture, you don't need to add anything else.
CAUTION: Adding only plain water to your cooling system can be dangerous. Plain water, or some other liquid such as alcohol, can boil before the proper coolant mixture will. Your vehicle's coolant warning system is set for the proper coolant mixture. With plain water or the wrong mixture, your engine could get too hot but you would not get the overheat warning. Your engine could catch fire and you or others could be burned. Use a 50/50 mixture of clean, drinkable water and DEX-COOL coolant.
NOTICE: If you use an improper coolant mixture, your engine could overheat and be badly damaged. The repair cost would not be covered by your warranty. Too much water in the mixture can freeze and crack the engine, radiator, heater core and other parts.
If you have to add coolant more than four times a year, check your cooling system.
NOTICE: If you use the proper coolant, you do not have to add extra inhibitors or additives which claim to improve the system. These can be harmful.
Engine
WHAT KIND OF ENGINE OIL TO USE
Two factors should be considered when determining type of oil to use in a vehicle:
The engine requires oil meeting GM Standard GM6094M. Use only oil that meets this standard.
SAE 5W-30 is the only viscosity grade recommended for use in GM vehicles. If the temperature is greater than -18°C (0°F) and if SAE 5W-30 is not available, you may use SAE 10W-30. Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). If the temperature falls below -20°C (-4°F), it is recommended that you use either an SAE 5W-30 synthetic oil or an SAE 0W-30 oil. Both will provide easier cold starting and better protection for your engine at extremely low temperature.
ENGINE OIL ADDITIVES
Do NOT add engine oil additives. The recommended oils with the starburst symbol that meet GM Standard GM6094M are all that is needed for good performance and engine protection.
Engine Oil
API Classification Look for Starburst Symbol
Above -18°C (0°F) 5W-30 or 10W-30
Below -20°C (-4°F) 5W-30 synthetic or 0W-30
Fluid- A/T
Transmission Fluid Type
Type DEXRON III or Equivalent
Fuel
GASOLINE OCTANE
Use regular unleaded gasoline with a posted octane of 87 or higher. If the octane is less than 87, you may get a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you might damage your engine. A little pinging noise when you accelerate or drive uphill is considered normal. This does not indicate a problem exists or that a higher-octane fuel is necessary. If you are using 87 octane or higher-octane fuel and hear heavy knocking, your engine needs service.
GASOLINE SPECIFICATIONS
It is recommended that gasoline meet specifications which were developed by automobile manufacturers around the world and contained in the World-Wide Fuel Charter which is available from the Alliance of Automobile Manufacturers at www.autoalliance.org/fuel_charter.htm. Gasoline meeting these specifications could provide improved driveability and emission control system performance compared to other gasoline.
In Canada, look for the "Auto Makers' Choice" label on the pump.
CALIFORNIA FUEL
If your vehicle is certified to meet California Emission Standards (see the underhood emission control label), it is designed to operate on fuels that meet California specifications. If this fuel is not available in states adopting California emissions standards, your vehicle will operate satisfactorily on fuels meeting federal specifications, but emission control system performance may be affected. The malfunction indicator lamp may turn on (see Malfunction Indicator Lamp ) and your vehicle may fail a smog-check test. If this occurs, return to your authorized GM dealer for diagnosis. If it is determined that the condition is caused by the type of fuel used, repairs may not be covered by your warranty.
ADDITIVES
To provide cleaner air, all gasoline in the United States are now required to contain additives that will help prevent engine and fuel system deposits from forming, allowing your emission control system to work properly. You should not have to add anything to your fuel. However, some gasoline contain only the minimum amount of additive required to meet U.S. Environmental Protection Agency regulations. General Motors recommends that you buy gasoline that are advertised to help keep fuel injectors and intake valves clean. If your vehicle experiences problems due to dirty injectors or valves, try a different brand of gasoline.
Gasoline containing oxygenates, such as ethers and ethanol, and reformulated gasoline may be available in your area to contribute to clean air. General Motors recommends that you use these gasoline, particularly if they comply with the specifications described earlier.
NOTICE: Your vehicle was not designed for fuel that contains methanol. Do not use fuel containing methanol. It can corrode metal parts in your fuel system and also damage the plastic and rubber parts. That damage would not be covered under your warranty.
Some gasoline that are not reformulated for low emissions may contain an octane-enhancing additive called methylcyclopentadienyl manganese tricarbonyl (MMT); ask the attendant where you buy gasoline whether the fuel contains MMT. General Motors does not recommend the use of such gasoline Fuels containing MMT can reduce the life of spark plugs and the performance of the emission control system may be affected. The malfunction indicator lamp may turn on. If this occurs, return to your authorized GM dealer for service.
FUELS IN FOREIGN COUNTRIES
If you plan on driving in another country outside the United States or Canada, the proper fuel may be hard to find. Never use leaded gasoline or any other fuel not recommended in the previous text on fuel. Costly repairs caused by use of improper fuel would not be covered by your warranty.
To check the fuel availability, ask an auto club, or contact a major oil company that does business in the country where you will be driving.
Heating and Air Conditioning Information
Refrigerant Oil Type
REFRIGERANT OIL
PAG Oil GM P/N 12378526 (Canadian P/N 88900060)
Refrigerant Type
Air Conditioning Refrigerant R134a P/N 12356150 U.S. (10953485 Canada)
Maintenance Information
RECOMMENDED FLUIDS AND LUBRICANTS
Look for and use ONLY the oils, fluids and fuel that meet GM Specification. Oil or fluid that does not have the correct specification designation can cause damage not covered by the warranty. Do NOT use oil or fluid additives.
CHASSIS LUBRICATION
Chassis Lubricant (GM P/N U.S. 12377985, in Canada 88901242, or equivalent) or lubricant meeting requirements of NLGI # 2, Category LB or GC-LB GM P/N 1051344 or equivalent.
CLUTCH LINKAGE PIVOT POINTS
Chassis Lubricant GM P/N 12377985, a lubricant meeting the requirements of NLGI # 2, Category LB or GC-LB or the equivalent.
HINGES, HOOD AND DOOR, FUEL DOOR, GLOVE BOX DOOR, CONSOLE DOOR AND REAR COMPARTMENT LID HINGES
Multi-Purpose Lubricant, Superlube® GM P/N 12346241 or (Canadian P/N 10953474) or equivalent
FLOOR SHIFT LINKAGE
Lubriplate lubricant aerosol, GM P/N 12346293 in Canada 992723 or lubricant meeting the requirements of NLGI # 2, category LB or GC-LB.
HINGES AND LOCKS
Multi-Purpose lubricant Superlube(R), GM P/N 12346241 or equivalent.
KEY LOCK CYLINDERS
Multi-Purpose lubricant Superlube(R), GM P/N 12346241 (Canadian P/N 10953474) or equivalent.
MISC. LINKAGE, LATCHES, PIVOTS AND SPRING ANCHORS
Lubriplate lubricant aerosol, GM P/N U.S. 12346293, in Canada 992723 or lubricant meeting the requirements of NLGI # 2, category LB or GC-LB.
PARKING BRAKE CABLE GUIDES
Chassis lubricant, GM P/N 12377985 or lubricant meeting the requirements of NLGI # 2, category LB or GC-LB.
SUNROOF TRACK
Lubriplate Lubricant Aerosol (Saturn Part No. 21038869 or GM Part No. U.S. 12346293, in Canada 992723) or lubricant meeting requirements of NLGI # 2, Category LB or GC-LB.
WEATHERSTRIP CONDITIONING
Dielectric Silicone Grease, GM P/N U.S. 12345579, in Canada 1974984, or equivalent.
WINDSHIELD WASHER SOLVENT
GM Optikleen(R) washer solvent, GM P/N 1051515 (Canadian P/N 992667) or equivalent.
Steering and Suspension Information
POWER STEERING SYSTEM
GM Power Steering Fluid GM P/N 89021184 (Canadian P/N 89021186) or equivalent.
Supercharger
Supercharger Oil
GM Performance Part #12345982 or equivalent
