Thread: Now what? Seat belt light and chime...
Results 1 to 12 of 12
  1. #1 Now what? Seat belt light and chime...
    SWPA
    This just started yesterday, but my seatbelt light on the cluster keeps lighting up/blinking, and the chime keeps going off even though my seatbelt is securely fastened. No one else is in the car, and nothing is on the seats.
    I've tried unbuckling and rebuckling, tugging hard on the belt, wiggling the belt and it still does it. Occasionally it will be fine and the thing wont chime for 10-15 minutes, but then it starts again.
    Loose wire issue? Grounding issue? Burn the car to the ground?
  2. #2 Re: Now what? Seat belt light and chime...
    St. Cloud, MN
    Burn the car to the ground option.
    I would assume a lose connection.
  3. #3 Re: Now what? Seat belt light and chime...
    you got a bunch of wires under the seat, i bet one is crimped or cut, or lose connector. the wire you want is the one that comes out the bottom of the seat belt, the side you clip into. it runs to the bottom of the seat.
    if you unplug the wire, the belt light and chime should never come on again.
  4. #4 Re: Now what? Seat belt light and chime...
    SWPA
    I figured this was the cause. Am I able to access it without removing/unbolting the seat? I tried to reach down there to see what I could feel and it felt pretty cramped.
  5. #5 Re: Now what? Seat belt light and chime...
    if you have a power seat lift the rear, and slide it forward, if not 2 t 45 bolts i think hold it down in the back, recline the seat back, then lift the back up, and lift the front, they got a hook on the front.
    dont lift to far till you see where the disconnects are, or you'll rip them apart. should be a clip on the frame, with wires to it.
  6. #6 Re: Now what? Seat belt light and chime...
    SWPA
    Thanks. Hopefully I get out of work at a decent time again tomorrow and can unhook this stupid thing.
  7. #7 Re: Now what? Seat belt light and chime...
    Chilliwack BC
    Had the same problem on mine when i first got it. they had to replace the buckle on the d/s to correct it....
  8. #8 Re: Now what? Seat belt light and chime...
    SWPA
    Well whatever I did after I got home from work seemed to cure it. I reached down there trying to figure out where the plug was and must have moved the wire enough to not ground out on anything. Whole way to work, and whole way home no ding. If it comes back I will unplug it.
    Now I just need to cure my random air bag light at highway speed.
  9. #9 Re: Now what? Seat belt light and chime...
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    This was just happening to my 07 and randomly fixed itself..that **** cray.
  10. #10 Re: Now what? Seat belt light and chime...
    SE Level Member tankrc's Avatar
    warren, ohio
    I wire in the seat belt buck go bad. For a new it 125 form dealer or find one the junkyard
  11. #11 Re: Now what? Seat belt light and chime...
    SWPA
    Any idea which plug-in to unplug? The annoyance has returned. I put the seat forward and tilted it forward only to see about 5 different plug-ins. There are two on the floor and 3 up on the bottom of the seat. I tried to trace wires but cant feel where any wires come off the buckle assembly because I can't even get my hand on the side.
  12. #12 Re: Now what? Seat belt light and chime...
    SWPA
    Just to update I figured this out. Easiest way to access is to slide the seat as far forward as possible and tilt the bottom forward as far as possible. On the bottom side of the seat closer to the console there are two plug ins. There is one single wire black plug in that needs unplugged. Its a bit of a pain in the ass but a flat head screw driver and the right angle will pop it right out.
  1. Seat Belt Warning Chime
    By Omen87 in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2011, 07:13 PM
  2. SEE IF YOU CAN ANSWER THIS! Seat belt chime???
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 06-10-2011, 01:34 AM
  3. Seat belt rewind and performance mode light
    By That Guy in forum General Tech Discussion
    Last Post: 08-01-2009, 04:39 AM
  4. seat belt ?
    By crewsn in forum General Tech Discussion
    Last Post: 04-17-2009, 10:19 PM
