Thread: Original Tires/Spark Plugs
Results 1 to 20 of 31
  1. #1 Original Tires/Spark Plugs
    Illinois
    Anyone know what the orginal tires and spark plugs were for an '04 Pontiac Grand Prix GT 3800 Series 3?
  2. #2 Re: Original Tires/Spark Plugs
    GT Level Member starscream5000's Avatar
    Kentucky
    Spark plugs are iridium (read, expensive and a waste of money). The original wires are probably along the lines of AC Delco.
    You do not want to put original type spark plugs in the car anyway, the cars are prone to KR in stock form as it is. Do yourself a favor and get one step colder on the plugs.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  3. #3 Re: Original Tires/Spark Plugs
    Illinois
    Ok. So what should I go with for spark plugs? And should the gap stay at .060" with a different plug? Just curious about the tires.
  4. #4 Re: Original Tires/Spark Plugs
    Tires should be whatever you feel comfortable running...but most of the time the factory tire size is 225/60/R16.
    As for plugs...old motor technology...use old spark plugs. Autolite 606's gapped @ .055".
    Done. For wires...get Duralast Lifetime warranty ones from AutoZone,
  5. #5 Re: Original Tires/Spark Plugs
    Kentucky
    AL 606's are one step colder, correct? I've got AL 104's and I know those are 2 steps colder.
  6. #6 Re: Original Tires/Spark Plugs
    No, AL606's are stock equivalent...605's are just a tad cooler.
  7. #7 Re: Original Tires/Spark Plugs
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Is the OP aware the copper plugs have to be changed 8X as often as iridium plugs?
  8. #8 Re: Original Tires/Spark Plugs
    Illinois
    Good information, thanks. I was thinking the same thing. Having to change them more often, as hard as the back ones are to get to, doesn't look fun. But I will take your advice and go with the Autolites. So, the concensus is AL 606 @ .055"?
  9. #9 Re: Original Tires/Spark Plugs
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Quote Originally Posted by quickster View Post
    Yes stick with the stock heat range you don't need colder plugs on a NA car.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  10. #10 Re: Original Tires/Spark Plugs
    Illinois
    The only plugs autozone and O'Reillys list are the irridium plugs. I googled and found there are different plugs, traditional, flat pack, copper-core. What should I ask for?
  11. #11 Re: Original Tires/Spark Plugs
    just walk up the counter and ask for autolite plugs. I dont think they list them on the internet on there website.
  12. #12 Re: Original Tires/Spark Plugs
    Kentucky
    Yeah, don't tell them what it's for, just say you need 6 autolite 606 copper plugs.
  13. #13 Re: Original Tires/Spark Plugs
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by starscream5000 View Post
    That is exactly what I did at Advanced Auto.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  14. #14 Re: Original Tires/Spark Plugs
    SE Level Member ls1freek's Avatar
    Sublette, Ks
    Ok, so I have an 05 GTP, 80k miles, probably a good idea to change them by now... What do you guys recommend I put in there? I'm new to the whole boost stuff... I've got lots of experience in N/A... Are the NGK TR55's cooler then my stockers? Or should I go TR6's? Or should I stay away from NGK's with boost? I'm running NGK TR55's in my Vette N/A.
    2005 Grand Prix GTP w/CompG
    - Stock
  15. #15 Re: Original Tires/Spark Plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I ran tr6's in mine, I liked the plug. I got Less misfires at idle then with the autolight 103s, but alittle bit more KR. If your stock NGK TR55: 1 Heat Range Cooler. TR6=2 colder. Not sure of the stock heat range NGK plug, But there fine to run on boosted car Ls1freek
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  16. #16 Re: Original Tires/Spark Plugs
    Sublette, Ks
    Quote Originally Posted by 01gpgt01 View Post
    Thanks man... Hmm, mabe I should be running a hotter plug in my Vette lol
    Oh BTW, how many miles will the TR's normally go?
    - Stock
  17. #17 Re: Original Tires/Spark Plugs
    Hagerstown,Md
    50K miles+. There Iriduim
  18. #18 Re: Original Tires/Spark Plugs
    "TR6" is copper.
    "TR6IX" is iridium.
    "TR6GP" is platinum.
    see the trend yet?
    In the TR55, the first five is the heat range, the second one indicates its pre-gapped to .059".
    Never trust this as plugs ARE dropped between the manufacturer and your local store.
    NGK claims the 5 heat range is stock for our cars.
  19. #19 Re: Original Tires/Spark Plugs
    Sublette, Ks
    Hmmm.....
    - Stock
  20. #20 Re: Original Tires/Spark Plugs
    T means its a 14 MM reach and the R means it has a resistor.
  1. spark plugs
    By gtpdriver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 01:22 PM
  2. spark plugs...
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2010, 09:40 PM
  3. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  4. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
