Thread: HUD Problem. Please help.
Results 1 to 20 of 29
  1. #1 HUD Problem. Please help.
    GT Level Member VejGTP's Avatar
    USA
    I've had my 04 GTP for at least 6 months and the HUD has worked perfectly so far. I got in the other day and I noticed that it wasn't showing up on my windshield. I checked the fuses and everything was alright, I even replaced it just to make sure and still no HUD.
    I ended up looking at a different angle and noticed that the display was as far UP as it could go (Impossible to see while driving.) Problem is: the button to adjust the HUD DOWN isn't working. The UP button works because if I press it I can see the little green lines apear on the edges of the rectangle display letting me know that it's being adjusted.
    I'm not sure how it got up so far, because I've only adjusted the display a few times to put it in the right spot for driving, but it's stuck up there. That's the best way I could think to describe it, but does anyone know how I can fix the down button or why it's not working?
    I'd appreciate any help!
    2004 GTP Comp G. Wizaired CAI
  2. #2 Re: HUD Problem. Please help.
    Oct 2008
    Calgary, Alberta
    Sounds like the spring holding the ange of the mirror to the adjusting arm went, or somehow slipped off so you will have to disassemble the case to reser the mirror and spring. Sorry no pics (I have a 98, different HUD)
  3. #3 Re: HUD Problem. Please help.
    USA
    Hmm, I figured it was something like that. But when I press the 'Down' button, if feels exactly the same as when I press 'Up'.. It doesn't feel like I'm not actually pressing a button, it feels normal.
    That's why I thought it might be a different problem. But you're pretty sure it's the spring?
  4. #4 Re: HUD Problem. Please help.
    USA
    After reading your post again it sounds like your saying the problem is in the dashboard part of the HUD and not in the button used to adjust it. If anyone could help me find a tutorial or pictures on how to fix this I would appreciate it.
  5. #5 Re: HUD Problem. Please help.
    Oct 2008
    Calgary, Alberta
  6. #6 Re: HUD Problem. Please help.
    USA
    Wow, thanks for the guides..
    Looks like a pain in the ass to fix, but it will be a nice little project I guess.
  7. #7 Re: HUD Problem. Please help.
    GT Level Member Whitehispanic's Avatar
    Westborough
    I did this on mine like 4 months it is hard as s@$(;$ but I found the easiest way is to take both pillars off then just tug on that piece that it's is in until all clips unlock and take the hub out. I will post a little more specific post of how to do it easier cause some of the instructions seems like u hav to take the whole dash apart when it really is only like 7 parts. This afternoon I'll post something up to help u out man.
    *sig too tall*
  8. #8 Re: HUD Problem. Please help.
    USA
    Easier is always welcome in my book lol. I'd really appreciate it
  9. #9 Re: HUD Problem. Please help.
    USA
  10. #10 Re: HUD Problem. Please help.
    Westborough
    Sorry I have not gotten to write it up but I'll post it maybe later tonight
    *sig too tall*
  11. #11 Re: HUD Problem. Please help.
    Westborough
    Basically do what this post says,
    HUD - Heads Up Display for Pontiac Grand Prix 2004 Repair Instructions (from above post)
    but me instead of drilling another hole in the plastic I just got a small washer and superglued it to the little spring, this prevents it from ever happening again, because you will have metal that the spring will be attached to and not plastic, because i am pretty sure that if you drill a hole through the plastic in little time it will happen again. It sounds harder than it is.
    *sig too tall*
  12. #12 Re: HUD Problem. Please help.
    USA
    Apart from using superglue on the spring, did you say there was a way to get to the HUD without taking apart the whole dash?
  13. #13 Re: HUD Problem. Please help.
    Westborough
    That is the best one to use it makes everything really easy but instead of drilling use a very small washer and super glue it to where the plastic so you can attached the spring hook
    *sig too tall*
  14. #14 Re: HUD Problem. Please help.
    USA
    Alright, I appreciate the help.
    How long do you think it'll take to fix this? For someone that's never done anything like this before.
  15. #15 Re: HUD Problem. Please help.
    Westborough
    Man to tell you the truth I had never done this in my life before and I was scared to break or not be able to put it back together it takes about 1 hour man if you do it at the speed I did I took my time and it takes about 30 to 45 min to put it back together so I would allow my self to be safe about 2 hours but again I did it really slow cause I did not want to break anything.
    *sig too tall*
  16. #16 Re: HUD Problem. Please help.
    USA
    Not bad at all. Did you print out those instructions?
  17. #17 Re: HUD Problem. Please help.
    Westborough
    Yeah I took my laptop outside then I ended up printing them cause I ran out of battery lol
    *sig too tall*
  18. #18 Re: HUD Problem. Please help.
    USA
    Lol alright. Thanks for all the information. I'll try to get this done within the next week or two. I'll let you know how it turns out!
  19. #19 Re: HUD Problem. Please help.
    Westborough
    Yeah man def I will be waiting to hear from you
    *sig too tall*
  20. #20 Re: HUD Problem. Please help.
    Jul 2010
    Kansas City
    This happened with mine not 5 days ago, so glad I stumbled upon this site! I got laid off yesterday, so it looks like I'll have plenty of time to fix it! Thanks for posting the instructions, much appreciated.
  1. A/C Problem
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:09 PM
  2. car problem
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 02-09-2010, 08:09 PM
  3. a/c problem
    By mtz956 in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 10:05 PM
  4. this might be a problem soon
    By Yung615 in forum Introductions/Noob Questions
    Last Post: 10-25-2009, 09:50 AM
  5. hid problem?
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 05-12-2009, 02:34 PM
