So I don't need another one of those aluminum brackets again?
Not if you plan on getting a supercharged coil pack bracket...they aren't aluminum.
i found mine on a 97 N/A olds intriuge.
Be sure to sand it and give it a couple coats of rustcheck paint.
Keep it nicer looking for longer.
Glad to know that I'm not the only one with this issue. I hate to pay the dealer $83 for this bracket. Does anyone know an aftermarket site and what is the exact name of the part?
Appreciate the help.
its the coil bracket.
Its a factory part, not sure how an aftermarket site would be able to help you much considering most yards only sell it with the engine.
I got mine and some other stuff for $20 whereas another yard I called wanted closer to $100 for it.
You could try searching classifieds on 3800 sites to see if anyone has one for sale though.
shouldn't be over 10 bucks at pullapart... I get them all the time and resell or powdercoat them and sell. Any l67 should have it if its in a wbody the ssei's don't IIRC
i want to say my buddy pulled mine off of an old bonneville or regal or something like that...
Is there anywhere online that i can find this mount? or do i need to go to a junkyard or something? one of the ears broke on my mount, likely from the previous owner over tightening it.
Mine broke the exact same way and i just changed it for the 3rd time just a couple of months ago. I got it off a 99 or older GP GT, put some 100lb wire around it to help support it and its good so far.
Not to hijack a thread or anything but the driver side bracket in the inside the black bushing thing cracked and made the driver side black thing ( i thinks its the dogbone) loose. Should i just get another one from a junk yard?
^ more like bringing a thread back from the dead.
The black thing is the bushing in the dog bone. They will wear out eventually and can be purchased through a vendor. Or you could pull the dog bone if you want. You could just upgrade to shorter dog bones for like $40 from ZZP, or spend the coin on the billet ones.
I hope this helps somewhat, i did this last weekend
http://www.grandprixforums.net/upper...ket-60192.html
