Thread: Headlight Stuck!! Clip won't budge!
Results 1 to 5 of 5
  1. #1 Headlight Stuck!! Clip won't budge!
    SE Level Member pr84704p's Avatar
    Westchester, NY
    Whoever last put in the headlight for my car must have forced it in as i can see it is not set in properly because of the headlamp popping out the side slightly. I am trying to lift up the white clip, which works fine for the other side, but it wont lift. I do not want to snap it, so i am not sure what to do. Has anyone had this problem? If so, please help me out.
  2. #2 Re: Headlight Stuck!! Clip won't budge!
    Wooster, Ohio
    use pliers, pull hard...that normally does it
  3. #3 Re: Headlight Stuck!! Clip won't budge!
    Westchester, NY
    Have you done this without it snapping? It seems to be in real tight, and i hope that little plastic piece wont snap.
  4. #4 Re: Headlight Stuck!! Clip won't budge!
    Wooster, Ohio
    yea, i work in a huge body shop and i tear down tons of cars everyday and i've never broke one, and i've had A LOT stick like that, especially the ones with mad front end damage. a few good tugs with pliers wont hurt, and if it does i would imagine there not very much
  5. #5 Re: Headlight Stuck!! Clip won't budge!
    Westchester, NY
    Thanks.
  1. Exhaust Clip
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-17-2009, 12:48 AM
  2. Missing Clip
    By zofsharick@gmail.com in forum Off Topic Discussion
    Last Post: 08-30-2009, 03:51 PM
  3. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
  4. My exhaust clip
    By ROTTMAN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 07:52 PM
  5. Old '5th Gear' Video Clip
    Last Post: 11-14-2008, 10:10 PM
