#1
Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
I'm hearing and reading a lot of things and wanted to see what you guys think as well. I'm rebuilding my tranny and wonder what will be recommended for my 04 GTP. I know Dex VI is the route but I was curious about
The Dex VI mixed with CAT fluid? And what's the ratio?
And or Amsoil?
Any thoughts...
Sent from my SM-N950U using Tapatalk
#2
Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
Turbo is the way to go.
09-20-2018
If this was 2004 it would still be DEX 3 on the dipstick as I though it was 2005-2006 that switched to the newest DEX 6 as the older fluid was phased out (superseded).
For as simple as these transmissions are and for what the fluid has to do I'd toss that cheap dex 3 right back in it without a single care in the world.
Putting in DEX 6 or using amsoils or cat fluid isn't going to do some voodoo magic and make it run better.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#3
09-20-2018
Fivefingerdeathpunch
Agreed. For a daily driver, the type of fluid is less important the the sustained operating temperature. Take the money you save and put it towards a cooler.
#4
I break stuff
09-20-2018
I run amsoil in all my vehicles, trans, oil etc.
#5
Haha true for the voodoo part. I've upgraded input shaft/chains and installed a few things in the Valve body from Sonnax and also added 3rd clutch piston from Sonnax. Trying to get what's best for what I can afford now. This tranny cant fail me anymore haha. If it does, it'll be my mistake haha
#6
#7
09-21-2018
Search on my name and the cat fluid. I forget how much Dave at TEP said to add. It might have been half or so.. but don't do it w/o confirming it.
The reason for doing the cat fluid was because it sticks to components better and keeps them lubed better under stress.
