Hey guys I am having some issues installing my halos, i have pretty much all the hardware installed in the headlight but the halos nor the projector will turn on, I do have some loose wires and a empty connector. Here are some pics
thank you
thank you
That's how I have my leds hooked up the thin white wire is the positive and blacks are negative they hook up to my turn signal bulb for day time running lights.
what a hack wire job holy crap, boggled my mind to help ha
The very thin black and red wires at the bottom of the housing go to the turn signal bulb not you're main power source for the halo lights.
The baby blue wire that is spliced from the connection is the low beam power and black ground of course the red wire is for the high beam
So connect the halo wires to the turn signal basically
My corner and side marker both blink simultaneously
Yeah but there are 3 wires if I'm not mistaken on the blinker bulb, one steady power one ground and one power wire that makes it blink.all you need to do is tap into the one that doesn't blink.
Went to go take a quick shot of the plug. And as you can see there is three if I'm not mistaken it should be the brown wire you need to tap for positive and black is negative
Ok il give it a whirl thank you
Thanks for the help GTP89 they are working
