i have a 01 L67 in my 97 gtp....now , heres the problem. This car was someone elses projectand i now own it ...there is supposedly a 01 engine n Tranny in the car.
the blower on the car is from a 97 as it has the black metal piece (has 2 male pieces on it for vacuum hoses) comin out of the blower by the BBV .none of the vacuum system is hooked up so im starting from scratch here...i've figured out that the 97 GTP has the 'evap canister purge valve' and 'evap vacuum switch' mounted on the back of the engine...i do not have these pieces as they didn't come with the car. so i've been looking up vacuum diagrams for the 97 L67 online and there are 2 different ones that i have found but need verification as to which diagram is right
This link shows a diagram an if u notice, it shows a vacuum line going to the trans....i didnt think the 97 gtp was a vacuum operated transnot to mention that there are only 2 fittings where the diagram shows that the line to the tranny would go.
GTP :: 1997 gtp L67 vacuum diagram picture by ArkanzanWheeler - Photobucket
Now this diagram was posted on GPF not long ago for a 97 GTP but does not show a vacuum line to the tranny. (u may have to scroll down the thread for the diagram....sry)
http://www.grandprixforums.net/1997-...elp-43820.html
which diagram should i be following?
